If I install stronger PC power supply in terms of watts
Upgrading to a higher wattage power supply does not pose a risk of damaging components in a PC. Even if a power supply has a higher capacity, the system will only draw the amount of power it needs. For example, if the total power requirement of the components is 50 W and a 100 W power supply is installed, the PC will still only consume 50 W. There is no waste of power in this scenario; the power supply simply has more capacity than is currently utilized. Overclocking may benefit from a higher wattage supply, but it is not necessary for standard operation.
R A V E N
...than my current unit,is there danger that some component in my PC will be destroyed?
Computer science news on Phys.org
Although if you intend on overclocking I think this is helpful.
But if my PC requires less power overall,does that mean that remaining power will be wasted?
If you have components that use a total of 50 W of power and you put in a 100 W supply then your computer will still just use 50 W of power. You won't "waste power", but your power supply will have more capacity than is being used.
DaleSpam & Mk,
thank you for your time and answers!
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
