3 Input Majority Logic Circuit
4 replies · 7K views · last reply
eren.kizildag
I want to implement a three input majority logic (when at least two of its inputs are 1, the output will be logic 1) by using only 2-input NAND gates. It is required to find the most simple one, with the lowest number of NAND gates, I could construct one with 6 NAND gates, but does anybody know a much simpler way for this? Or six gates is the simplest one? Any help is appreciated...
Actually, it is like a homework; it is a part of pre-laboratory which should be designed before coming to lab.. And it will be implemented on lab.
Using only 2 input nand gates I can't find a solution with less than 6 either.
Can you use 2-input open collector NAND gates (SN7401's) and resistor OR-ing?
