Magnitude of bullet fired into gel
  • Thread starter Thread starter tcharger130
    Bullet Magnitude
The discussion revolves around calculating the magnitude of the bullet's deceleration after being fired into a dense material. The bullet, with an initial speed of 330 m/s, comes to a stop after traveling 25.0 cm. The relevant equation of motion, v^2 = u^2 + 2as, is suggested to find the acceleration, where the final speed is 0 m/s. The expected outcome is a negative value for acceleration, indicating it opposes the bullet's initial direction. Understanding this concept is crucial for solving the problem accurately.
tcharger130
A rifle bullet with a muzzle speed of 330 m/s is fired directly into a special dense material that stops the bullet in 25.0 cm. Assuming the bullet's deceleration to be constant, what is its magnitude?
x=25.0cm
V=330 m/s
I don't fully understand the problem, to me it sounds like they want the magnitude of force exerted on the bullet in the opposite direction it was fired? I'm really confused.
Thanks
No, they are looking for the magnitude of the bullet's acceleration (deceleration).
The initial speed, u, is 330m/s, the final speed, v is 0 m/s since the bullet comes to rest. The bullet travels a distance, s of 0.25m.
The equation of motion v^2=u^2 +2as should be of help.
Note that this will give you a negative acceleration which is to be expected as it is opposing the direction of motion.
