A ball is thrown upward direction , is it a -ve displacement
When a ball is thrown upward, its displacement can be considered negative if the chosen coordinate system defines upward as negative and downward as positive. The direction of the axis is arbitrary, and consistency in the chosen convention is crucial. For example, if the starting point is set at the top of a tower, upward throws would yield negative displacements until the ball falls below that point. Conversely, if upward is defined as positive, then the displacement of the ball thrown upward is positive. Ultimately, the interpretation of displacement is dependent on the established reference frame.
md abul hasan
when a ball is thrown in upward direction --how can it be a negative displacement?
You have the choice to say that the axis perpendicular to the ground points upward or downward (i.e., in the direction of gravity). It is purely arbitrary and won't affect the results, provided that the convention chosen is strictly adhered to: once you've chosen which way is positive, stick to it!
It is an arbitrary choice. Having made a choice one simply has to be consistent.
If one were considering a situation where one is standing on the ground throwing a ball upwards so that all distances are up, it would be sensible and simplest to say up is positive.
If one were throwing objects off the top of a tower so that most of the displacements were below the starting point, one could well choose to take the starting point at the top of the tower as zero and make the downwards direction positive. Then, if one did throw a ball upwards, its displacement would be negative until it fell past the top of the tower.
is toward gravity +ve ?
Yes, if the throwing the ball upwards results in a negative displacement, then the force of gravity is postive.
Likes md abul hasan
