Relativity Questions: Answers Explained
  • Thread starter Thread starter TheScienceOrca
    Relativity
TheScienceOrca
After learning more about relativity, and the vast amount of knowledge that is on this forum, I would like to clear up a few questions I had about relativity.
1) If Alice is on a planet and sees Bob fly away from her through the universe at .9c relative to her and bob then throws a baseball at .9c in the same direction he is traveling in I have a few questions;
If you let each object move for 1 second relative to the object itself would you see from a fourth frame of reference; Alice, Bob, and Bob's baseball should be moving for different amounts of time relative to you as they are traveling at different speeds.
If you measured the distance from Alice and Bob would it be .9ls?
If you measured the distance from Bob and Bobs Baseball Would it be .9ls?
If you measured the distance between Alice and Bobs Baseball would it be 1.8ls?
Is the baseball moving at 0.9c relative to Bob? I assume so, but you should make these things explicit. General rule: any time you specify a distance, time, or speed, you need to specify what it's relative to. For distances, you also need to specify at what time the distance is measured; and for times, you need to specify between which two events the time is measured.
Yes, 1 second for each of these objects, according to the object's own clock, will correspond to a different amount of time according to you since all three of them are moving relative to you, and at different speeds.
All of these questions are not well-defined, because you haven't said what you're measuring the distance relative to, nor have you specified at what time the distances are being measured.
What is the fourth frame of reference? How fast are Alice, Bob and Mr. Baseball traveling with respect to it?
It could be, if the fourth frame happens to be the one in which Alice is at rest or the one in which Bob is at rest. Try calculating it from some other frame.
It could be, if the fourth frame happens to be the one in which Bob is at rest or the one in which Bob's baseball is at rest. Try calculating it from some other frame.
It could be, if the fourth frame happens to be the one in which Bob is at rest. Try calculating it from some other frame.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
9K
