- #1
AryRezvani
- 67
- 0
W=∫ Fx dx
I think you got to split this one in terms of axis.
∫(2yi + x2j) dx
Pretty lost on it.
No, the force is not along the blue line.AryRezvani said:Understood, so quick question, is the blue line the force? Then the other lines simply components of the force?
Still a little lost. We want to calculate the work required to move the object to the right first. Force is constant right? So would you use fΔrCosθ?
A force acting on a particle can be defined as a push or pull that changes the motion or shape of an object.
A force acting on a particle can be measured in units of newtons (N) using a device called a force meter or spring scale.
A force acting on a particle can cause it to accelerate, decelerate, or change direction depending on the direction and magnitude of the force.
According to Newton's Second Law of Motion, force is directly proportional to acceleration, meaning that the greater the force, the greater the acceleration of the particle.
The direction of a force acting on a particle in the xy plane will determine the path of the particle's motion. If the force is in the same direction as the particle's velocity, the particle will speed up. If the force is opposite to the particle's velocity, the particle will slow down. If the force is perpendicular to the particle's velocity, the particle will change direction but maintain the same speed.
