A Problem on Thermal Equilibrium
An aluminum rod at 140°C and a copper rod at an unknown temperature T are placed in thermal contact, ultimately reaching thermal equilibrium at the same length. The problem involves calculating the initial temperature of the copper rod and the final equilibrium temperature of both rods, using the principles of heat transfer and thermal expansion. Key equations include the heat transfer equation Q = mcΔT and the linear expansion equation Δl = αΔT. The discussion emphasizes that the heat lost by the aluminum must equal the heat gained by the copper, leading to two equations with two unknowns. The final results indicate that the original temperature of the copper rod is 89.7°C, and the final equilibrium temperature is 119.2°C.
smallbadwolf
The problem is
An aluminum rod with cross-sectional area 0.0400 cm^2 and length 80.00 cm at a temperature of 140.0 Celcius is laid alongside a copper rod of cross-sectional area 0.0200 cm^2 and length 79.92 cm at temperature T. The two rods are laid alongside each other so that they are in thermal contact. No heat is lost to the surroundings, and after they have come to thermal equilibrium, they are observed to be the same length. Calculate the original temperature T of the copper rod and the final temperature of the rods after they come to equilibrium.
I tried using the MCAT equation (Q = mc X Delta T) but I can't seem to derive a formula that works for the lengths of TWO objects in thermal equilbrium. In my textbook there is a formula that says that
The Change in the Length = Alpha X Initial Length X The Change in Temperature
I'm not sure if this helps, but I have worked hard on this problem, and asked several people for advice, ultimately gaining no progress. My book has the answers, but I need to know how to solve this one, not just the answer. But if it helps, the answer is:
89.7 Degrees Celcius for the Original Temperature of Copper.
119.2 Degrees Celcius for the final temperature of the two rods after they come to equilbrium.
Thanks to all that help me.
Eq. 1) Q = m cp \Delta\,T
and
Eq. 2) \Delta l = \alpha\,\Delta\,T, where \alpha is the thermal expansion coefficient of the material.
Let Th = the initial 140°C.
One has to find Teq (i.e. equilibrium), and Tc (i.e. cold). And one has two equations.
The heat lost from Al has to equal heat absorbed by copper.
\Delta T (Al) = Th - Teq
\Delta T (Cu) = Tc - Teq
If one needs to find mass, it is just density * volume.
One also knows that the length at Teq is the same for both rods, so that gives a second equation with Th, Teq, and Tc by virtue of Eq. 2.
But how does one find T_c?
Also, I regret mentioning that I was given the following values:
P_a = 2.7 X 10^3 Kg / m^3
C_a = 910 J/Kg-k
P_c = 8.4 X 10 ^3 Kg/ m^3
C_c = 390 J/ Kg-k
Coefficient of Linear Expansion for Aluminum:
2.4 X 10^(-5)
Coefficient of Linear Expansion for Copper:
1.7 X 10^(-5)
If one writes the thermal equilibrium equation in terms of Tc and Teq, and one writes the equation for the equivalent length in terms of the same temperatures, then one has two equations and two unknowns, which one wishes to find.
One can use direct substitution, to find either temperature.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
