A question about Magnetic Fields and A Charge
When a charged particle enters a magnetic field at a 90-degree angle, the force acting on it is perpendicular to its velocity, resulting in no work being done on the particle. Consequently, the kinetic energy of the particle remains unchanged. However, while the momentum's magnitude is constant, its direction changes due to the continuous acceleration from the magnetic force. This leads to circular motion, confirming that the particle does not progress in space. Therefore, the correct answer is that kinetic energy is unchanged while momentum is changed.
Hevonen
[SOLVED] A question about Magnetic Fields and A Charge
A charged particle enters in 90 degrees to the magnetic field i.e. the force on the charge is F = qvB as sin (angle) = 1. The question is which are the effects on the kinetic energy and momentum of the particle?
Alternatives:
A. KE => Changed
Momentum => Changed
B. KE => Unchanged
Momentum => Changed
The solution is B but I do not why? Please, help me.
I think...
As the force is perpendicular to the displacement no work (W=fxcos(angle)) will be done. It's kinetic energy, a scalar, remains unchanged.
However, the force does accelerate the charged particle. This acceleration is perpendicular to it's velocity. The momentum vector changes in direction, not magnitude.
Does this help?
In other words, the particle will circle around and around again ie it is not actually progressing anywhere. It stays where it is and circles. Hence, can it be said that there is no work done ie. KE is unchanged?
Yes I believe so.
Thanks! I think I understood :)
