A question about the loop gain and source contained port impedance
The discussion centers on understanding loop gain and port impedance in a negative impedance oscillator model. It raises the question of whether R must be greater than r to achieve a loop gain greater than one. The direction of current is also debated, with participants noting that different assumptions about current direction yield varying results for port impedance. One participant suggests that the orientation of the circuit diagram should not affect its operation, while another wonders if port impedance can change based on measurement direction. Ultimately, the conversation highlights the complexities of analyzing circuit behavior in relation to current direction and impedance calculations.
genxium
I recently got a problem that confuses for days, the picture for this problem is in the attachment field, is there someone can tell me that, if an oscillator is topology is described using the negative impedance model in the picture, should I have R>r to ensure that the loop gain is larger than 1?
The second question is, is the current direction a significant element to consider ? Because to construct a negative impedance port, usually a voltage source or current source will be used, the source is directional.
I actually get different result by assuming different current directions in the second attached picture, I think the direction really matters, but if so, it'll be confusing that how I should choose the direction !
I'm afraid there's no equation for this question.
No meaningful attempt made. The port impedance I got for picture 2 is R_{eq}=\frac{U}{i_U}=\frac{Z_1 \cdot (Z_2+Z_3)}{(Z_1+Z_2+Z_3)+g_m \cdot Z_1 \cdot Z_2}, and for inverse direction current, the impedance I got is R_{eq}=\frac{Z_1 \cdot (Z_2+Z_3)}{(Z_1+Z_2+Z_3)-g_m \cdot Z_1 \cdot Z_2}
Which current(s) in particular are you referring to when you say "inverse current direction"? Is it the controlled source?
Thanks for your reply ^_^
I'm sorry for the poor statement, when i said "INVERSE DIRECTION", I meant the direction of "current" in picture 1, and direction of "i_U" in picture 2.
Hmm. If iU is reversed then would not this imply that U is reversed also, yielding the same U/iU for the impedance?
Dear gneil, I'm afraid not, when I calculated R_{eq} in the inverse current direction, I flipped the whole picture vertically, I think this reverses both the voltage and current :)
I don't see how the orientation of the drawing on paper could possibly change the circuit's operation!
My reasoning:
Use the transformation shown in the attachments.
Z_a=\frac{Z_1 \cdot Z_3}{Z_1+Z_2+Z_3}
Z_b=\frac{Z_2 \cdot Z_3}{Z_1+Z_2+Z_3}
Z_c=\frac{Z_1 \cdot Z_2}{Z_1+Z_2+Z_3}
U=i_U \cdot Z_a+(i_U-g_m \cdot U) \cdot Z_c, the port impedance R_{eq} is
R_{eq}=\frac{Z_1 \cdot (Z_2+Z_3)}{(Z_1+Z_2+Z_3)+g_m \cdot Z_1 \cdot Z_2}
I'm sorry gneill, you're right ~ Thanks a lot for your help ! But I'm still curious, is there any port impedance that would change subject to measuring direction (like flipping +/-)?
Sure, if the network contained some non-linear component(s) such as diodes.
