A simple system of two masses and two pulleys
The discussion revolves around solving a physics problem involving two masses and two pulleys, with the user seeking assistance in determining the correct expression for the acceleration of the masses. The user has attempted the problem multiple times but received different answers. A forum member emphasizes the need to see the user's work to provide effective help. It is pointed out that the assumption of equal accelerations for both masses is incorrect due to the constraints imposed by the rope's constant length. The conversation highlights the importance of understanding the relationships and constraints in the system to arrive at the correct solution.
adamm150
A simple system of mass
mainly newtons second law
hey there,
I am confusing what is the right answer to this system of mass, I solved it a couple of time and I got different answers. can you help me with that?
I need to find the expression of the acceleration of the 2 masses.
thanks a lot,Adam.
Likes Delta2
Hi Adamm150,
Welcome to Physics Forums!
Can you show us your attempt? We can't offer any help or advice without first seeing in detail what you've tried. Thanks.
on the left middle; if the system was stretch all the way. it will be easier to find the length equation, thanks a lot/
I see you somehow got that a1=a2. That is incorrect.
Likes Delta2 and Chestermiller
ok i will try it agian
Consider that the rope attached to M2 is of constant length. That places a constraint on the relationship between a1 and a2.
Likes Hamiltonian
