A woman throws a ball at a vertical wall d = 5.0 m away.
The problem involves a woman throwing a ball at a vertical wall, with specific parameters including distance to the wall, initial height, and launch velocity. The discussion centers around the ball's trajectory, the effects of its collision with the wall, and subsequent motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of the ball's trajectory, including the horizontal and vertical components of velocity upon impact with the wall. There are questions about how to approach the problem after the ball bounces off the wall and how to determine the new initial conditions for the subsequent motion.
Some participants have provided calculations for parts of the problem, such as the time in the air before hitting the wall and the height at which the ball strikes the wall. However, there is ongoing exploration regarding the motion after the ball hits the wall, with hints and suggestions being offered to guide the discussion.
Participants are working under the assumption that air resistance can be ignored, and they are considering the effects of reversing the horizontal component of velocity after the collision with the wall.
cbking1306
A woman throws a ball at a vertical wall d = 3.2 m away. The ball is h = 1.6 m above ground when it leaves the woman's hand with an initial velocity of 14 m/s at 45°. When the ball hits the wall, the horizontal component of its velocity is reversed; the vertical component remains unchanged. (Ignore any effects due to air resistance.)
(a) Where does the ball hit the ground?
m (away from the wall)
(b) How long was the ball in the air before it hit the wall?
s
(c) Where did the ball hit the wall?
m (above the ground)
(d) How long was the ball in the air after it left the wall?
s
I found part B was .323s and part C is 4.29m. I don't know how to solve the second part.
s
s
You should have calculated the horizontal and vertical components of the ball's velocity when it struck the wall. Use the hint at the end of the problem statement and figure out the trajectory of the ball after it bounces off the wall. (bold portion).
After the ball hits the wall, you have to start a new problem with an initial velocity and height again (except going in the opposite direction).
Chet
I found the initial velocity in the x direction to be 14cos(225)=5.14 m/s and the initial velocity in the y direction to be 14sin(225)=-13.02 m/s. The equation I am trying to plug it into is V1y(SQ)=V0y(SQ)+2aΔt
sorry meant Δy at the end of that equation
9K
  • · Replies 21 ·
