Acceleration due to gravity homework
queen of hearts
what is the acceleration due to gravity at a distance of one Earth radius above Earth's surface?
Use the expression for the gravitational force, then equate that force to ma, there being an m in your expression for the gravitational force, the "m"s would divide out.
