Acceleration in a Pulley System
The discussion focuses on the calculation of acceleration in a pulley system for an AP Physics review. The original poster uses a specific formula to derive an acceleration of 2 m/s² but is challenged by another participant who points out that the applied force minus friction should equal mass times acceleration. They emphasize the importance of understanding the underlying physics principles rather than relying on a specific formula, which may not apply to all scenarios. The conversation highlights the need for a proper force analysis and the application of Newton's second law for accurate problem-solving. Overall, the participants stress the significance of foundational physics concepts over memorized equations.
LemonBeef
Hey, I'm doing a review packet for my AP Physics class, and I was just looking for some confirmation that I'm on the right track.
Here's the image of the problem: http://img297.imageshack.us/img297/2681/imgrx6.jpg
Ignore the scribbles. I'm using the formula a = ((mB)(g)- (µ)(mA)(g)(cos Ø)) / (mA + mB), and I'm pretty sure the answer is 2 m/s/s for both parts a and c.
Can anyone confirm/deny? Thanks.
you are missing something...
applied force-friction=mass*accln
50-[.2*100]= 10 *a
>50-20=10*a
>30=10*a
>a=3m/s^2
this is enough for you to proceed in second case...
go ahead...
Since the situations are physically different, the acceleration will be different. Don't use a canned formula* (which applies only in special cases). Instead, learn to apply first principles (force analysis and Newton's 2nd law)--then you can solve any problem tossed at you without having to memorize dozens of limited-use results.
*Does that equation even make sense for case I? There's only one mass.
