Advice for the design of an automatic door opener
  • Thread starter Thread starter cherrycoke
    Automatic Design
The discussion focuses on designing an automated trap door opener that requires a motor and mechanical components like gears, springs, or power screws. The door measures 36 inches wide and 48 inches long, weighing 60 pounds, and must open to 110 degrees in 20 seconds. Initial calculations for power requirements have been made, but there is uncertainty about the design execution, particularly with using a linear actuator due to its limitations in opening angles. Suggestions include considering a right angle gear motor or exploring rotary motion mechanisms similar to window operations. The conversation emphasizes the need for a robust motor to handle the vertical opening and the importance of clarifying design specifications.
cherrycoke
Hello all,
I need to design an automated trap door opener incorporating a motor and at least one of the following: gears, springs, or power screws. It is 36 inches wide and 48 inches long. It is hinged along its width. The door weighs 60 pounds. When closed it is flush with the floor. It must rotate to 110 degrees when opened in 20 seconds.
I've calculated how much power I would need to rotate the door at the angle and time constraint, but I do not know how to execute the design. I was thinking of using a linear actuator but I'm not sure how to incorporate that with the wide opening angle of the door. Linear actuators I have seen used to open doors so far have opened too slowly and at most 90 degrees.
Any help would be appreciated, thank you !
cherrycoke said:
Hello all,
Welcome to the PF.
Can you post your initial sketches and calculations? :smile:
Hello,
I hope the image attachment works. Here is my attempt at a kinematic approach first to find what HP motor I needed. Please let me know if I made wrong assumptions. Thank you!
Likes bsheikho and berkeman
bsheikho said:
But that opens horizonatally, so the loading on the motor and opener are pretty light. He is asking about opening a trap door vertically, no?
True, though I don't see how this concept can't be applied vertically with a stronger motor.
Its basically how all windows open, use rotary motion to swing open the windows.
That example is a bit more complicated with a rail and bushing,
Is there any foot traffic on or around the top area of the trap door when it is closed.
Likes berkeman
Right angle gear motor is enough either worm gear box or helical type
You mentioned the size of the door as 36 in x 48 in but in your image it is in 'ft'
