Air friction on a A4 paper ( Classical Mechanics )
bob195
How could u find the drag/friction due to air on a A4 size page dropped perpendicular to the ground. There are about 20 sheets and is dropped about waist height. The tricky thing is no instruments are aloud. Only your senses...
F=-cv where c is the constant due to air friction. v is the vel and F the force of air
have no clue because i would think u would at least need a stop watch.
If you are given no instruments you will need to make estimates.
what estimates? u will have c for the friction and g for the gravity.u could considers some sort of acceleration from looking at the system.could it be done? i would think it would be of the function speed and maybe have to differentiate a few times but would not know where to start...
Because of the lack of instrument the best that can be done is a crude estimate.The falling paper tends to rock to and fro but there doesn't seem to be a net vertical acceleration.I think you are expected to assume it reaches terminal velocity this being when the weight of the paper is balanced by air resistance.
thanks Dadface!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
