Airplane Vector: Solving for Direction of Flight
In summary, in order for a plane to fly due north with an airspeed of 250 km/h and a wind blowing at 80 km/h in the direction 60 degrees east of north, it should head in the direction of <-69.3, ?>. This can be found by drawing a vector triangle and using trigonometry or vector components to find the unknown angle. The key is to remember that all vectors are relative, so the velocity of the plane relative to the ground is equal to the windspeed plus the airspeed.
EV33
196
A plane flies at an airspeed of 250 km/h. A wind is blowing at 80km/h in the direction 60 degrees east of north. In what direction should the head in order to fly due north.
I turned the wind into a vector assuming that the wind is blowing 30 degrees from the x axis
<69.3,40>
I then thought that because the final direction of the plane would be pointing up the Y axis that the i component should be zero, and to make the wind's i component and the airplane's heading i component equal to zero then the air plane would have to head in the following direction of this vector <-69.3, ? >. so I don't know the j component.
I think my main problem is that I don't know how to apply the 250 km/h airspeed to the problem because I want the speed relative to the ground, not to the air.
Can anyone help me out on converting that 250 airspeed to ground speed? or how to apply it in a useful way to the problem?
Hi EV33! :smile:
Simplest way is to draw a vector triangle …
you know that one side is due north, one side is length 80 at 60º to north, and the third side has length 250 …
put arrows on them to make sure they're the right way round, and use either trig or components to find the unknown angle. :wink:
Thank you.
That gave me the right answers.
I still have one problem though. I don't understand how I can add two vectors together that are from different reference points. The 250 is in reference to the moving air. The 80 is in reference to the ground. Can someone explain to me how this works?
Maybe I have misunderstood what airspeed means. I take airspeed as meaning the speed relative to the air but does it just really mean its speed in the air relative to the ground?
Hi EV33! :smile:
(just got up :zzz: …)
All vectors are relative.
For a position vector, that's obvious … the vector is from one position to another.
But it's also true for a velocity vector … it's from one velocity to another!
So just as you can write a position vector as AP, and get equations like AP + PG = AG,
you can write a velocity vector as AP, and get equations like AP + PG = AG,
except perhaps it's clearer if you emphasise that they're velocities by writing VAP + VPG = VAG.
In this case, A P and G are (the velocities of) the ground the air and the plane.
If you always write it this way, you won't go wrong. :wink:
Yes, airspeed is VAP, the velocity of the plane relative to the air.
So the velocity of the plane relative to the ground is VGP = VGA + VAP = windspeed + airspeed.
(silly name isn't it? … "windspeed" is the correct term for the speed of the wind, but "airspeed" isn't the correct term for the speed of the air! :rolleyes:)​
1. How is the direction of flight calculated in an airplane vector?
The direction of flight is calculated using a mathematical concept known as vector addition. This involves breaking down the airplane's motion into its horizontal and vertical components, and then using trigonometric formulas to determine the resulting direction of flight.
2. What factors can affect the direction of flight in an airplane vector?
The main factors that can affect the direction of flight in an airplane vector are wind speed and direction, the weight and balance of the aircraft, and the thrust and angle of the engines. These factors can cause the airplane to deviate from its intended flight path and change its direction of flight.
3. How does an airplane's heading differ from its direction of flight?
An airplane's heading refers to the direction that its nose is pointing in, while its direction of flight refers to the direction that the airplane is actually moving in. This means that the heading can differ from the direction of flight if the airplane is affected by external factors like wind or turbulence.
4. Can an airplane vector be used to determine the speed of an aircraft?
No, an airplane vector is used specifically to determine the direction of flight. To determine the speed of an aircraft, other factors such as airspeed, ground speed, and wind speed must be taken into account.
5. How does the pilot use an airplane vector in the cockpit?
The pilot uses an airplane vector to plan and maintain the aircraft's flight path. By knowing the direction of flight, the pilot can adjust the heading and make necessary corrections to stay on course. The airplane vector is also used to communicate with air traffic control and other aircraft in the vicinity to ensure safe and efficient flight operations.
