All possible planes, given two points
To find the equation of all planes containing points P(2, -1, 1) and Q(1, 0, 0), a vector PQ is calculated as (-1, -1, 1). An additional vector is needed for the cross product to determine the plane's normal vector, leading to the realization that infinite planes can pass through the two points. The discussion emphasizes that three points uniquely define one plane, while fewer points can lead to multiple planes. The arithmetic of vector calculations is crucial, and substituting points P and Q into the scalar equation is necessary to ensure accuracy in determining the plane's equation.
The Subject
Find the equation of all planes containing the points P(2, -1, 1) and Q(1, 0, 0)
I use PQ to get a vector, (-1, -1, 1). I some how need to use another vector so I can use the cross product to find the planes.
So i let another point A(x, y, z) and find a vector PA, (x+1, y+1, z-1)?
If i use the cross product i get (-z-y, z+x, 2-y+x) with a scalar equation of a(-z-y)+b(z+x)+c(2-y+x) = 0
I don't feel confident with my conclusion, is there a concept I'm misunderstanding about finding the planes?
How many points determine one plane? What if you have fewer points than this number?
If you cross vector PQ with some other vector, how many planes does that determine?
Thanks for the insightful question, I actually had to check my understanding.
3 points, anything less contains no planes?
PQ cross with another vector gives me 1 plane.
Since PQ cross another vector (x y z), this should give me any possible planes for some arbitrary vector, right?
3 points uniquely determine 1 plane. If you have one or two points, how many different planes can pass thru these points?
Try it and see.
Oh okay, it contains infinite planes!
So I let the arbitrary vector (1, 1, 1) the I get - 2a+2b+2c=for some d.
I just realize, how do I ensure this scalar equation is correct?
Since I have points P and Q that needs to go through, it makes sense to sub abc with points P and Q. It seems I'm getting different numbers for d
Check your arithmetic. ##PQ \ne <-1, -1, 1>##.
Oh wow how did that happen! Thanks
Maybe you should review the equation of the plane in 3 dimensions:
https://en.wikipedia.org/wiki/Plane_(geometry)
Likes The Subject
