Am I setting this integral up correctly?
  • Thread starter Thread starter SarahAlbert
    Integral
SarahAlbert
Use spherical coordinates to evaluate the integral over a sphere of radius R.
The equation of my sphere would be x^2+y^2+z^2=R^2
Please see the attached file.
I have attached a file to show my work so far. Evaluating the integral once it is set up should be fine, I'm concerned it's not set up correctly. Thank you.
Hello,
You want to reconsider dV. ## \ \ \ dV \ne dr\, d\phi \,d\theta ##.
I'm beginning to think that it's also not as easy as (pcos∂)^2 since my radius is R then p=R so isn't it ∫∫∫pcos∂)^2p^2
Nope. You're integrating p over a radius of R. It's not the same thing.
You are calculating a volume integral, so your p is running from 0 to R .
Your function to integrate is ##\ f(r, \theta, \phi) = (r\cos\theta)^2## as you wrote correctly.
Now check out how you can express a volume element in spherical coordinates ##dV(r, \theta, \phi)## , e.g. as shown here or here
So it would then be (rcosθ)^2r^2sinθdrdθdphi which becomes r^2sinθcosθdrdθdphi and then become r^2sin(2θ)/2drdθdphi
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
