Amount of water spilled when the temperature is changed
A glass bottle with a capacity of 250 cm³ filled with water at 20°C experiences a volume change when heated to 50°C. The coefficient of volume expansion for water is given as β = 0.21 x 10^-3 K^-1. Initial calculations led to an incorrect volume change of 0.048 cm³, while the correct answer is 1.6 cm³. The confusion arose from the use of logarithmic functions in the volume expansion equations, but it was clarified that the two methods of deriving volume change are equivalent for small temperature changes. The discussion concluded with the understanding that the exponential function can be approximated by a linear expression for small values of βΔT.
Phys12
A glass bottle of nominal capacity 250 cm3 is filled brim full of water at 20oC. If the bottle and content are heated to 50oC, how much water spills over? (For water, β=0.21X10-3 K-1. Assume that the expansion of the glass is negligible.)
(dv/dT)/v = β[/B]
Let vo = 250 cm3, To=20oC, T1 = 50oC, to find: v1-v0
From the equation of coefficient of volume of expansion,
dv/v = βdT
Integrating both sides, we get: ln(v1) - ln(vo) = 0.21x10-3 *ln(50) - ln(20)
=> ln(v1) = 5.521 + 0.21x10-3 x ln(5/2)
=> v1 = 250.048
=> Δv = 0.048cm3
However, the answer is 1.6 cm3, what am I doing wrong?
Cutter Ketch said:
dV/dT = B V
Does not evaluate to logarithms
LOL, thanks, I don't know why I saw a T in the equation!
Wait, if I move the volume to the other side of the equation, wouldn't I get log for volume? dv/V = BdT => ln(V1/V0) = B (T1 - T0)?
That’s why I immediately deleted the post. I hit post too fast. On my phone I type very slowly, so it is embarrassing that my thumbs nevertheless out run my brain. Sorry.
Ah, I see, no problem.
So I did the integral! β = 1/v(dv/dT)
=> βdT = dv/v => βΔT = ln(v1/v0) => v1 = v0eΔT). When I plug in the values of v0, β and ΔT, I get the value of v1 as 251.58, hence, Δv = 1.58. Which is what the answer is. However, in a solution manual I found online, they use the equation Δv = v0βΔT. And they get the correct answer. My question is, are these two equivalent?
From my derivation, v1 = v0e(βΔT)
From the solutions manual, v1 = v0 + v0βΔT
How are v0e(βΔT) and v0 + v0βΔT the same?
Phys12 said:
ln(50) - ln(20)
How does integrating dT produce a ln function?
Yeah, I did that incorrectly. I've fixed that in my post right before this one
It's a series expansion. For small values of ##\beta \Delta T## to first order, ##e^{\beta \Delta t} \approx1+\beta \Delta T.## Calculate it both ways and see what you get.
Likes Chestermiller
Yeah, I did something similar and I see that behavior. I plotted the two functions: https://www.desmos.com/calculator/vrhjyq5tk0. So,e^(βΔt) is the correct expression while the other one is just an approximation for small Δts. Awesome, thank you!
