Angular Displacement of bike pedals
The problem involves determining the angular displacement of a bicycle tire based on a given angular velocity function over a specified time interval. The subject area relates to calculus, specifically integration and angular motion.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the integration of the angular velocity function to find angular displacement, with some questioning the correctness of their integration steps and results.
Several participants have identified potential errors in their integration attempts and are exploring corrections. There is an ongoing examination of the integration process and the implications of different approaches, but no consensus has been reached regarding the correct expression for angular displacement.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a focus on ensuring the integration is performed correctly, with specific attention to the treatment of trigonometric functions.
snowmx0090
An exhausted bicyclist pedals somewhat erratically, so that the angular velocity of his tires follows the equation,
ω(t)=(1/2)t - (1/4)sin(2t)
where represents time (measured in seconds).
There is a spot of paint on the front tire of the bicycle. Take the position of the spot at time to be at angle radians with respect to an axis parallel to the ground (and perpendicular to the axis of rotation of the tire) and measure positive angles in the direction of the tire's rotation. What angular displacement has the spot of paint undergone between time 0 and 2 seconds?
Express your answer in radians.
I thought you would take the integral of the equation from t=0 to t=2 in which the equation would then be (1/4)t^2 + (1/2)cos(2t) but this was wrong. Where should I start with this equation?
Check your integration--the second term has an error.
Would the equation after integrating be (1/4)t^2 + (1/4)cos(2t)? Was this my mistake?
There is still a mistake. What does [tex]\frac{d}{dt}(\frac{1}{4}\cos (2t))[/tex] equal?
you would have to use a u substitute. Set u=2t, and du=2. So instead of it being 1/4cos(2t), it would be 1/8cos(2t).
final : ((1/4)(t^2))+((1/8)(cos2t)) from 0 to 2 seconds
.918295 - .125 = .793 radians
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 38 ·
  • · Replies 20 ·
