How Is Angular Momentum Calculated Without Considering Gravity and Viscosity?
Angular momentum can be calculated without considering gravity and viscosity by focusing on the forces and torques acting on the system. The discussion highlights confusion regarding the derivation of the equation, particularly concerning the altitude and angle of the variable ##b_1##. Participants express uncertainty about the force from the plate and its impact on torque calculations. The incoming flow generates a downward force on the plate, which creates a reaction torque about the chosen axis. Clarification on defining the r and u vectors in the equation is needed to fully understand the cross product computation.
Est120
write the macroscopic angular momentum balance for the following problem
see image
we neglect gravity and viscosity efects
i really can't understand how does the author managed to get the equation in the image
Not making any sense to me either.
Altitude at ##\frac 12b_1## from where?
##b_1## is at an angle, so ##b_1-b_{2a}## doesn’t seem right.
And what about the force from the plate? We don't know where that is centred, so we can't set the axis so as to eliminate its torque.
it's an idealized problem, all i need to know is how they compute the cross product , there is no viscosity so there is no friction with the plate
For that, I need you to define the r and u vectors in the boxed equation.
It's not to do with friction. The incoming flow exerts a vertically downward force ##w_1v_1## on the plate. The reaction from the plate likely has a torque about the chosen axis.
