Why Is the Calculated Angular Momentum of the Pucks Zero?
The calculated angular momentum of the system of three pucks is initially thought to be zero due to vector cancellation, but this is incorrect. Each puck contributes to the angular momentum, which is calculated using the formula Lθ = Iwθ, where I is the moment of inertia and w is the angular velocity. The direction of the angular momentum vectors is perpendicular to the plane of rotation, meaning they do not cancel out. The correct approach involves calculating the angular momentum for each puck individually and summing them to find the total. Thus, the magnitude of the angular momentum should be derived from the contributions of all three pucks.
Joshua A
Three small, identical 0.70-kg pucks are attached to identical 0.50-m strings, tied together at a common center as shown in (Figure 1) . Pucks are whirled in circular motion at angular speed 3.0 s-1
What is the magnitude of the angular momentum of the system about the common center?
I = mr2
Lθ = Iwθ
Angular momentum is a vector, therefore the angular momentum of this system should be 0 kg m2/s as all the vectors will cancel out. The magnitude of that is also 0 kg m2/s.
Apparently this answer is wrong. Where am I going wrong? When they ask for the magnitude of the angular momentum, do they want me to find the magnitude of the angular momentum for each puck and then add the magnitudes together?
What is the direction of the angular momentum vectors?
The direction of the angular momentum vectors should be the same as the angular velocity vectors. I had assumed that the direction of the angular velocity vector would be in the direction of the motion of the puck (i.e. along the t axis). Looking back through my textbook, they do not actually specify a direction for the angular velocity, just the magnitude of the angular velocity. From a Google search, it seems that the direction is actually perpendicular to the plane of rotation, therefore the vectors would not cancel out as they are all pointing the same direction.
I assume the answer should then be:
Lθ1 = (0.70kg)(0.50m)2(3.0s-1)
for puck 1, and the same for pucks 2 and 3. Then the angular momentum of the system would be Lθ = Lθ1 + Lθ2 + Lθ3
Yes. In 2D motion, angular velocity (and momentum) is often simplified to a signed scalar: anticlockwise is positive and clockwise is negative. For 3D motion, you have to consider the full vector nature.
What is the SI unit of angular velocity?
Angular velocity? s-1 (or rad/s - normally, as far as I know, rad isn't specified)
Angular momentum is kg m2/s
The SI unit is rad/s, but radians are generally considered dimensionless.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
