How Does Angular Velocity Change in Different Yo-Yo Maneuvers?
The discussion focuses on calculating the angular velocity of a yo-yo modeled as a uniform cylindrical disk in two scenarios: when it falls and when the string is pulled upward. In part (a), the user attempts to derive the angular velocity after the yo-yo has fallen a distance L, using the total kinetic energy equation and the moment of inertia for the system. In part (b), the user expresses confusion about how to approach finding the angular velocity when the string is pulled, indicating uncertainty about using conservation of energy. The user acknowledges the need to consider the inertia of the lightweight hub in their calculations. Overall, the thread highlights the complexities of angular motion in different contexts involving yo-yo dynamics.
Physics122
A certain yo-yo can be modeled as a uniform cylindrical
disk with mass M and radius R and a lightweight hub of
radius ½R. A light string is wrapped around the hub.
(a) First, the yo-yo is allowed to fall. Find the angular
velocity of the yo-yo when the string has unwrapped a
distance L.
(b) Now, imagine that that you pull upward on the string such
that the yo-yo remains in the same place. Find the angular
velocity of the yo-yo when you have pulled the string
upward a distance of L.
(c) Explain in words why it makes sense that the answers to
parts (a) and (b) are different.
K (total) = .5 * I (center of mass) *w^2 + .5MR^2
I cm for a uniform cylindrical hub = .5M(R^2 + (.5R)^2)
(A)
K (total) = .5 * I (center of mass) *w^2 + .5MR^2 = MgL
W^2 = MgL/ (.5 *I (cm) + .5MR^2)
So..
W^2 = MgL/(.5 * (.5M(R^2 + (.5R)^2) + .5MR^2)
W^2 = MgL/(1/4Mr^2 + 1/16MR^2 + 1/2MR^2)
W^2 = gL/(13/16R^2)
Does that seem about right? (obviously need to make it the square root but just leaving it squared for now)
(b)
I assume I cannot use conservation of energy, so maybe I could solve this with the Work that is done? I dunno, I'm confused I guess I don't know where to begin
Thanks for any help fellow physics buds!
Just realized that I probably should have taken into account the Inertia of the lighweight middle area but that will just change the general format of the first problem. It's the second problem that remains confusing
