Angular velocity of bicycle wheel
The discussion revolves around calculating the angular velocity of a bicycle wheel given a linear velocity of 13.0 m/s and a wheel diameter of 0.660 m. The correct formula used is ω = v/r, leading to an initial calculation of 39.4 s-1. However, the confusion arises because the answer should be expressed in radians per second, which requires dividing by 2π, resulting in 6.27 radians per second, aligning with the option "e - none of the above." The thread highlights a common mistake regarding units in angular velocity calculations. Understanding the distinction between revolutions per second and radians per second is crucial for accurate results.
Nelson2436
A bicycle rider is moving with a velocity of 13.0 m/s. What is the angular velocity of his wheels if they have a diameter of 0.660m? Assume the wheels are rolling without slipping.
a) 39.4 m/s
b) 19.7 m/s
c) 39.4 s-1
d) 4.29 s-1
e) none of the above
v = ω r
ω = v/r
ω = (13m/s) / (0.330m) = 39.4 s-1
This problem was given on a test, I put "c" and got it wrong. It seems very straightforward and I'm not sure where I went wrong. Is there a mistake in my work? I am thinking it was most likely a mistake with the grading machine but I just wanted someone to confirm before I talked to the teacher. Thanks.
Your answer looks correct to me.
Likes Nelson2436
Yes, your answer is definitely correct. Note that you almost don't need the question. Just looking at the choice of answers, and assuming each wrong answer corresponds to a single likely error, (c) stands out as the common theme.
Likes Nelson2436
It's a units issue. The 39.4 technically has units of 'revolutions per second'. Divide by 2pi to get your answer in 'radians per second', which can be written as 1/second. This would make the correct result 6.27 radians per second, which matches up to 'e - none of the above'.
No, dividing tangential velocity by radius gives radians per second.
Anyway, this thread is three years old.
My mistake. I did a google search related to angular velocity of bikes and when this came up, I didn't look at the date stamp. The similar problems I was working on for my class included revolutions per second in their calculation and I jumped the gun.
