Another disagreement with course Line integral homework
1MileCrash
http://img39.imageshack.us/img39/6669/wileyplus.png
The field is conservative.
With their description of C, and using the Fundamental Theorem of Calculus for Line Integrals, would you evaluate
f(11/sqrt(2), 11/sqrt(2)) - f(0,0)
or
f(11/sqrt(2), 11/sqrt(2)) - f(11,0)
Their description of C, to me, is that we start at the origin and end at (11/sqrt(2), 11/sqrt(2)).
However, their "show solution" shows them doing:
Either I don't understand, or wiley plus has been wrong for the dozenth time. FYI my answer looks so strange because I kept changing it up to get it to accept.
The whole point of path independence is that I don't give a crap about where the circle or whatever starts, the point (11,0) is completely irrelevant!
or
It is not that simple. You have to integrate along a line from (0;0) to (11/√2;11/√2).
You can choose the path between (0;0) and (11/√2;11/√2) as you like. One easy choice is along the x-axis from (0;0) to (11/√2;0), then vertically up from (11/√2;0) to (11/√2;11/√2).
Show your work.
ehild
Wiley Plus is wrong. You're right.
1MikeCrash,
yes, the solution in the gray box is correct. I did not realize that it was yours.
ehild
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
