Understanding Pulleys in a Frictionless System
The discussion focuses on solving a physics problem involving a 47N weight and a 25N weight connected by a cord over a frictionless pulley. Participants debate the correct application of Newton's second law to determine the acceleration of the weights and the force on the cord. Initial calculations for acceleration are disputed, with suggestions to write out the equations for each weight separately. Clarifications about the system's configuration indicate that one weight is on a horizontal surface while the other hangs vertically. The final acceleration calculated is 3.0 m/s², but confusion remains regarding the setup and the forces involved.
kashiark
A 47N weight is pulled on a frictionless surface by a frictionless pulley that is attached to a 25N weight by a cord.
A. What is the acceleration of the 47N weight?
B. What is the force on the cord?
F=ma
A.
25=(47/9.8)a
a= about 5.2 m/s²
B. no clue whatsoever
Hi kashiark! :smile:
(is this a horizontal surface? is the weight hanging vertically off the end? :confused:)
Your A is wrong.
Start again …
write out Newton's second law three times: once for the 47N weight on its own, once for the 25N weight on its own, and once for the pair of weights together. :smile:
I'm understanding the problem to mean that one weight is on the ground and the other end is in the air, but if the heavier end is on the ground, wouldn't the cord just go limp and pull the lighter weight up to the top of the pulley?
47=9.8m
m= 4.8
25=9.8m
m= 2.6
I'm not sure how I would compose the third equation.
No, that must be wrong …
kashiark said:
A 47N weight is pulled on a frictionless surface …
the question clearly states that the weight stays on the surface …
I assume the rope starts horizontal, then goes over the pulley and hangs down vertically.
Your understanding definitely makes more sense though, but if that's the case, then the weight on the vertical cord would be pulling the weight on the surface horizontally, and you wouldn't have to account for its weight at all in A because it's pulling vertically right?
Ok, I just read that, and it's very ambiguous. Let's call WA the weight that's on the surface and WB the weight that's not. In part A, you wouldn't need to include WA's weight because it would be pulling it down, and WB's weight would be pulling it horizontally right?
Physics is equations.
Stop waffling … write out the equations for Newton's second law three times … what do you get?
47=9.8m
m= 4.8
25=9.8m
m= 2.6
Ok I'll stop for now, but I would greatly appreciate it if you could explain it to me. How's this:
22=a(2.6+4.8)
22=7.4a
a=3.0 m/s²
