Finding Local Extrema with Derivatives
To find two positive numbers whose product is 108 and minimize the sum of the first number plus three times the second, the equations xy = 108 and S = x + 3y are used. By substituting x with 108/y, the sum S can be expressed as S = (108/y) + 3y. The derivative dS/dy is calculated as -(108/y^2) + 3, which is set to zero to find critical points, yielding y = 6. The second derivative, 216/y^3, helps determine whether the critical point is a local minimum or maximum; if positive, it indicates a local minimum. Understanding derivatives through the power rule and graphing can clarify their relationships.
scorpa
Hey there!
You guys aren't going to believe that I can get stuck on something this pathetically easy, but I have to ask anyway.
Find two positive numbers whose product is 108 and the sum of the first number plus three times the second number is a minimum.
Here is what I've done:
xy = 108
x + 3y = S
Let x and y be the two numbers, and S the sum.
To find S substitute x = (108/y) into x + 3y = S
S = (108/y) + 3y
Now I need to take the derivative of the function, and set it equal to zero to find a critical number, but I can't get the right answer for this part, which is stupid because it should be so darn easy. I haven't done derivatives in awhile and now I am starting to forget them :mad:
This is what the book says :
dS/dy = -(108/y^2) + 3 = 0
3 = 108/y^2
y^2 = 36
y = 6
The second derivative the book says is 216/y^3
Can someone please explain how they got the derivatives to me? I feel absolutely stupid having to ask this but I figured I had better ask now so I understand it later. Thanks so much :redface:
What are the derivatives of a constant,of y=x and y=\frac{1}{x}...
U need them all.
Daniel.
scorpa said:
S = (108/y) + 3y
I'd rewrite this as S = 108y^{-1} + 3y
You use the power rule to find the derivative of each term. This identifies your critical points, but doesn't tell you for sure whether you have a local minimum or a local maximum.
Use the power rule, again, to find the derivative of your derivative (the second derivative). If the second derivative is greater than 0, you have a local minimum; If less than 0, a local maximum.
If you don't understand why, then graph your original function, your first derivative, and your second derivative. The relationship between them should be a little clearer.
