Applyings Newton 2nd Law and Kinematics
A 10,000 kg rocket experiences an upward thrust of 118,000 N, prompting a discussion on calculating its acceleration, distance traveled, and net force. The net force is determined by subtracting the gravitational force (approximately 100,000 N) from the thrust, resulting in 18,000 N. This leads to an acceleration of 1.8 m/s², calculated using the formula a = ΣF/m. The distance traveled in 20 seconds is found using d = 1/2at², yielding 360 meters. The final velocity after 20 seconds is calculated to be 36 m/s, confirming the rocket's acceleration.
jtwitty
A 10,000 kg rocket is acted upon by a upward thrust of 118,000N
How fast will the rocket be moving after 20 seconds? How far will it have moved in this time?
Also, how do i determine the net force
a = \SigmaF/m
d=1/2at2+vit
a = \SigmaForce/mass
a = 118,000/10,000
a = 11.8?
to find how far
d=1/2at2+vit
d=1/2(11.9)(202)
d=2360
What forces act on the rocket? (Hint: There are two.)
Finding the net force is the first step before you can calculate the acceleration.
gravity and the mass of the object?
The force of gravity is one force. You're given the other. (Mass is not a force.)
oh you the upward thrust.
so its 118,000N is one force and 100,000N is the force of the Earth due to the mass of the object multiplied by 10 (in class we always round gravity to ten)
Sounds good. So what's the net force?
doc al said:
sounds good. So what's the net force?
1.18n??
edit: wait no, that's the accelaration. the net force is 18? idk :(
jtwitty said:
1.18n??
Careful--You're missing a factor of a thousand!
idk what to do? :'(
Try this: If you had 20 million dollars and you spent 10 million, how much would you have left? 10 dollars?
10 million.
so would i have 18,000 as my netforce?
but don't i divide, not subtract?
Exactly.
Not to find the net force. But yes to find the acceleration. That's the next step.
ok so my acceleration would be 11.8 right?
sorry i wrote it wrong, i mean 11.8
How did you get 11.8?
a=\Sigmaf/m
a=
---- ok mid post i just realized i used the wrong number!
a=18,000/10,000
a=1.8??
jtwitty said:
a=\Sigmaf/m
a=
a=18,000/10,000
a=1.8??
Now you've got it.
yay
ok so i am using the d=1/2at2 formula
d=1/2(1.8)(202)
D=360?
jtwitty said:
yay
d=1/2(1.8)(202)
D=360?
Good! (What about the speed?)
d=vi/t?
360=vi/20
vi=7200?
(vi = initial velocity)
jtwitty said:
d=vi/t?
360=vi/20
vi=7200?
No. Instead, consider the definition of acceleration.
wait is this rght
v = d/t
v = 360/20
v = 18!
jtwitty said:
wait is this rght
v = d/t
v = 360/20
v = 18!
That would give you the average velocity as the rocket rises, not its velocity after 20 seconds.
it's accelerating isn't it?
a = vf -vi / t
1.8 = vf -0 / 20
1.8 = vf /20
36 = vf?
i think that's it :)
Good!
thank you so much doc al you're my hero :)
