Alex Hughes
- 54
- 13
So I've been learning how batteries work. What I learned is that a battery consists of 2 pieces of metal both with different electronegativities. These metals react with an electrolyte.
One metal (called the anode) is oxidized and has its electrons removed, leaving behind a positive ion which dissolves in the electrolytic solution. Once a conductor (like a wire) connects the two terminals, electrons flow from one metal (the anode) and into the cathode since they differ in electronegativities. A reduction reaction occurs here and the positive ions combine with the electrons.
My question is, shouldn't the terminals of a battery be neutral since even though the negative end of the battery gives up an electron, it also has its positive ion leftover dissolved into the solution. So if the terminals of a battery refer to the regions of a positive and negative potential and NOT a positive and negative charge, how can a positive and negative potential result from a neutral charge?
I've always been taught that potential is defined by bringing a positive test charge from infinity (therefore having an external electric field acting on it of 0) to whatever point your measuring near the charge and measuring the electric potential energy per charge. However, if the terminals of the battery were neutral, wouldn't that mean each would NOT have an associated electric potential?
Sorry for rambling but what I'm asking is: How can batteries have a positive and negative potential if the charges of their terminals are neutral?
