Atwood Machine simulation problem
In the Atwood Machine simulation, m1 is 1.0 kg and m2 is 1.1 kg, with m2 resting on the floor. The tension in the rope at 2.54 seconds is 9.789 N. The equilibrium condition is established with the equation Fn + T - m2*g = 0, leading to a calculated normal force (Fn) of approximately 1.0 N. The discussion confirms that the provided calculations are correct under the assumption of equilibrium. The normal force and tension values are crucial for understanding the system's dynamics.
extreme
Need a check on this one please. In an Atwood Machine simulation, m1 is 1.0kg and m2 is 1.1kg. m2 rests on the floor that exerts a normal force, Fn, on m2. when the system is in equalibrium, the tension, T, in the rope at 2.54s is 9.789. If Fn +T- m2*g = 0 then Fn = .991. Is this correct?
equilibrium
If the question is "What normal force does the floor exert on m2 when m2 rests on the floor?" then you're probably OK. (Although I have no idea what 2.54s has to do with anything.)
The forces on m2 are: F_n + T - m_2 g = 0; similarly, the forces on m1 are: T - m_1 g = 0. So F_n = (m_2 - m_1)g.
equilibrium
The question "What is the normal force, FN, and what is the tension, T, in the rope? T (at t = 2.54s) = ______. At equilibrium: FN + T – m2 • g = 0. Then FN = _______." This is a timed simulation and at 2.54s the rope tension,T, is 9.789
OK, now I see what you're talking about. Since T is given and equilibrium is assumed, your answer is correct; rounded off, the normal force would be 1.0 N.
equilibrium
Thanks for the quick reply.
A Full Stack Development Program prepares students to create end to end web applications using front end as well as back-end technologies. The purpose is to get experience in creating user interfaces, managing databases, and conducting server-side activities, resulting in a thorough understanding of how web platforms work. This skill is essential since it allows developers to participate at every step of a project, enhancing critical thinking and productivity. registering in Full Stack...
