How Do You Calculate the Average Force Exerted by a Gas Molecule in a Flask?
To calculate the average force exerted by a gas molecule in a flask, start by using the ideal gas law (PV=nRT) to determine the pressure. The pressure is found to be approximately 467.43 Pa for 0.075 mol of gas at 300 K in a 400 mL flask. Next, calculate the surface area of the flask, which requires finding the radius from the volume. The force can then be computed using the formula F=PA, but it is crucial to ensure all units are consistent, particularly using SI units. The discussion emphasizes the importance of unit consistency and correct calculations to arrive at the correct average force.
dalitwil
I have been having a hard time with the following question:
A 400 mL spherical flask contains 0.075 mol of an ideal gas at a temperature of 300 K. What is the average force-magnitude exerted on the walls of the flask by a single molecule?
I couldn't really start the problem because I have two unknowns: m and v. I need m to find v, and i need v to find F. Because it doesn't give me a molar mass, i am lost on how to find v, wondering if there is another approach I could take? Please help!
U can find the pressure (in Pa) and then compute the average force by multiplying the pressure in Pa with the surface area in m^{2}...U can't use kinetic theory,because computing the momentum transfer by a molecule would require knowledge of the average magnitude of velocity and the molecule's mass...
Daniel.
Think ideal gas law to find the pressure, then do as dextercioby said.
Ok so I used PV=nRT to find pressure:
P*(.4L) = (0.075)*(8.31)*(300)
=467.43Pa
Then I calculated the surface area by setting the volume equal to 3/4pi r^3:
find the radius (=.45708) and finding surface A=4pi*r^2 =2.6
Now calculating the F from F=PA gave me 1227. This was incorrect.
I also tried subsituting the volume with .0004m^3 (1L=10^-3m^3) and recalculating the P and A and it was still incorrect.
I don't understand what i did wrong, I understand the logic behind finding F this way, but my calculations are wrong. Can anyone please help me?
It can't be right.U got to be consistent with your units...Use SI-mKgs...
p=\frac{\nu RT}{V} \ [Pa]
p=\frac{0.075\cdot 10^{-3} \ \mbox{Kmol} \cdot 8314 \ \frac{\mbox{J}}{\mbox{Kmol}\cdot\mbox{K}} \cdot 300 \ \mbox{K}}{0.4\cdot 10^{-3} \ \mbox{m}^{3}}
and get that #.
Daniel.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
