About the reference to a working system , first of all here is a wiki article (yes I know about flaws in wiki but this doesn't seem to be one of them )
https://en.wikipedia.org/wiki/Alternator#Brushless_alternators
then ,
and here is a nice page for marine students that i just found
http://www.marinesite.info/2014/03/how-does-brushless-alternator-works.html
so basically these types of alternators have two parts, the main parts works exactly the same as if the current for the rotor would be supplied directly via sliding contacts , but the first side works like a rotary transformer, you have a primary winding (stator exciter coil) then a core (rotor armature) and a secondary winding that's rotating.
If my thinking is correct then if you take a tarnsformer , an ordinary one and just rotate the core while its working no changes to the induced current happen , but if you physically move one of the two coils either the pirmary or secondary , you get additional induced current due to the work done and additional increase or decrease in frequency depending on the speed and direction you move the coil with respect to the half period of the sine wave at that moment ?
What do you think is this reasoning correct?
In my case , I don't want to have these two parts because here the goal is to have the same DC poles on the rotor but just have them there without any sliding contacts that shorten the life of the device.since the main output part still has the usual design of DC rotor poles and a stationary output coil on the stator this generator still produces an output frequency which is fixed and related to its rpm, the rpm of the rotor.
In my case what I do is take away the rectifier first so that the rotor has a time varying polarity changing field as the field coil has.normally if I applied such field to a typical alternator the output induced would be a " cripple" it would probably self cancel at times and so on. So the geometry of what I'm talking about is a little different as I described earlier with the example of cylinder type solenoids and a rotor.
In my case I only need to have that exciter coil (field coil) made flux enter the rotor so that from the rotor it could be distributed along the output coils as it rotates.
the question is can i just link the flux from a stationary field coil into a moving rotor and then the flux from the rotor would resemble the same flux wixh is normally on a rotor who has windings on it , or do i physically need another set of coils on the rotor to get current in them which then would set up a rotating field.
maybe another way to explain this would be , take a transformer for example, now imagine somehow you are able to rotate the core around while its working , in terms of current induced in the secondary nothing would change because the core is uniform all around , so the b field seen by the secondary coil would see no difference.
take that same transformer now but imagine the core has two symmetrical gaps of equal length but opposite sides in the core.the primary flux created by the primary coil is still linked to the core but now as you move the core it becomes something similar to a reluctance generator , and now the secondary coil does feel additional forces from the rotating core.
In other words , imagine my generator is a transformer with the only difference that instead of all the secondary power coming from the primary with no moving parts , in my case the primary is just a small coil for setting up the field and the core is the rotating part and the secondary winding is the output coil, so the primary winding sets the flux and frequency , the core is moved by a mechanical power source and the secondary's induced current is the result of the pirmary + the mechanical force from the rotor.
you would ask, " Why on Earth one needs this" ? asnwer - I want a generator whose output frequency and even waveform to an extent can be fully controlled by the field current.
one of the positive sides of this could be a generator run on high frequency having the same power output with smaller dimensions than a generator with the same output power but an oridnary design.
something similar has already been thought out from one guy in the internet , only his version , which i talked much about here and there myself, has moving (sliding) contacts and in that particular design they can't be avoided due to the laws of physics sadly.
well I want ot hear what you think, i;ve tried to explain myself , although i believe I haven't done the best job one could want , but I tried.
