Why Do Certain Answers Apply in Basic Electric Field Questions?
The discussion centers on confusion regarding the correct answers to specific electric field questions. For question 16, the participant questions why option D is incorrect, despite intuitively choosing E based on parallel plates and uniform electric fields. The explanation highlights that the charge distribution in D does not yield the same electric field characteristics as E. In question 30, the participant mistakenly associates higher voltage with higher potential, but the correct answer is A, as the magnitude of the electric field is determined by the ratio of voltage change to distance. Understanding these principles clarifies the reasoning behind the correct answers.
DivideBy0
I'm confused about [question 16](http://image.prntscr.com/image/41a5c611927c44a7ac30104be3dd10ee.png) and [question 30](http://image.prntscr.com/image/a6aea3b9a8f04df9aca0dfe14054d4ce.png). The correct answers are e and a respectively.
For 16, why did D not work? Intuitively, I chose E because of parallel plates that have equal electric fields, but what is the integral for choice D and E and why are they different?
For 30, I thought higher voltage meant higher potential so I thought the answer should be C and D. Why is it A?
Welcome to PF, DivideBy0.
16. The graph shows a uniform charge distribution, independent of x. Consider the charge distribution described in D. What does it look like? What do you know about the electric field that results from such a distribution?
30. You need to consider only one thing. The magnitude of the electric field can be approximated by ##|\vec{E}|=|\frac{\Delta V}{\Delta s}|##. Where is this ratio the greatest?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
