How Does a Pulley System Affect Force and Energy Transfer?
  • Thread starter Thread starter Ronaldo21
    Energy Tension
The discussion revolves around a friction-free pulley system lifting a 600-N block. Participants seek clarification on the number of rope strands supporting the weight, the tension in each strand, and how the man's pulling affects the block's movement. Questions also arise about calculating the ideal mechanical advantage and the potential energy increase based on the work done. The need for a diagram is emphasized to aid understanding of the system's mechanics. Overall, the conversation highlights the complexities of force and energy transfer in pulley systems.
Ronaldo21
1. A 600-N block is lifted by the friction-free pulley system shown.
a. How many strands of rope support the 600-N weight?
b. What is the tension in each strand?
c. What is the tension in the end help by the man?
d. If the man pulls his end down 60 cm, how many cm will the weight rise?
e. What is the ideal mechanical advantage of the pulley system?
f. If the man exerts 60 Joules of work, what will be the increase of PE of the 600-N weight?
okay so for A is it just 1 because its just 1 rope.
and B do we do F*D?
c. the same thing?
idk I am really confused.
please help!
Can you show us the diagram?
