Solve Basic Vector Problem: Hawk Speed & Shadow Speed in m/s
  • Thread starter Thread starter olliepower
    Vector
To calculate the speed of a hawk's shadow on the ground when diving at 4.24 m/s at an angle of 61.7 degrees below the horizontal, the x component of the velocity vector is needed. The calculation using the formula A_x = A cos(θ) yields 2.01013 m/s. However, the user reports this answer was marked incorrect in their homework program. It is suggested to consult a professor for clarification on the calculation or potential errors in the homework system. Understanding the correct application of vector components is crucial for solving this problem accurately.
olliepower
When the Sun is directly overhead, a hawk dives toward the ground at a speed of 4.24 m/s
If the direction of his motion is at an angle of 61.7 below the horizontal, calculate the speed of his shadow along the ground
Answer in units of m/s
A_x = A cos\theta
I will want to find the x component of the velocity vector.
4.24 Cos (-61.7) = 2.01013
I put this answer into my homework program (Quest) and it was wrong. What am I missing here?
Welcome to PF, Ollie. Your calc seems correct to me.
Sounds like a good opportunity to visit your prof.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
20K
