What Was the Initial Frequency of the Trumpet Player?
The trumpet player initially hears 3 beats per second against a 440 Hz tuning fork, indicating her frequency is either 437 Hz or 443 Hz. After adjusting her trumpet, she hears 5 beats per second, suggesting a change in pitch. The discussion highlights that pulling out the tuning slide lowers the pitch, leading to a potential frequency of 435 Hz. However, the only consistent initial frequency that aligns with the observed beat frequencies is 437 Hz. Therefore, the initial frequency of the trumpet player is determined to be 437 Hz.
sugz
A trumpet player hears 3 beats per second when she plays a note and simultaneously sounds a
440 Hz tuning fork. After pulling her tuning valve out to slightly increase the length of her
trumpet, she hears 5 beats per second against the tuning fork. What was her initial frequency?
a) 437 Hz
b) 443 Hz
c) Either a) or b).
d) 435 Hz
e) 445 Hz
fbeat = |f2-f1|
I understand how the beat frequency is the difference of the 2 frequencies. So |f1-440| = 3 and |f2-440| = 5. So the first frequency can be 437 or 443 Hz but the answer in only 437 Hz, why?
The tiny increase in length that caused an extra 2 Hz in the beat frequency might provide [what is intended to be] the clue.
a) 437 Hz
b) 443 Hz
c) Either a) or b).
d) 435 Hz
e) 445 Hz
fbeat = |f2-f1|
Pulling out the tuning slide lowers all of the pitches. I think you are right.
She could have been flat (437) and pulled out, thinking she was sharp, going even flatter (435). She could also have been a little sharp (443) and pulled out too much, taking her down too far (435).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
