Block sliding down frictionless semicircle
The problem involves a block of mass sitting atop a frictionless semicircular bowl and seeks to determine the angle at which the block will slide off the bowl. The discussion revolves around concepts from dynamics and energy conservation.
  • Participants discuss the forces acting on the block, including normal force and gravity, and the resolution of these forces along the circular path. There is uncertainty about how to incorporate the normal force into the equations of motion. Some participants suggest using energy conservation to find relationships between the forces and the angle.
Guidance has been offered regarding the application of Newton's second law in the radial direction and the significance of the normal force being zero at the point of losing contact. Multiple interpretations of the problem are being explored, particularly concerning the resolution of gravitational components.
Participants express confusion about the proper method to resolve forces in a circular motion context, and there are references to previous discussions on similar problems. The original poster indicates difficulty in finding relevant resources despite prior searches.
platinumtucan
A block of mass, m, sits atop a semicircular bowl of radius, r, and the angle the radius makes with the horizontal is [tex]\theta[/tex]. Find what angle, [tex]\theta[/tex], the block will slide off the bowl.
[tex]\frac{1}{2}mv^2 + mgy = \frac{1}{2}mv^2 + mgy[/tex]
[tex]\alpha=ar[/tex]
[tex]a_{c}=\frac{v^2}{r}[/tex]
Drawing a free-body diagram, the forces I think at work are the normal force, gravity, and possibly a centripetal force. The resolution of gravity along a circular path is where my trouble begins. I don't think it's really equivalent to resolve gravity as the sum of two x and y vectors along an incline, since this is a circle. Maybe resolving into x=rcos[tex]\theta[/tex] and y=rsin[tex]\theta[/tex] and saying mgrcos[tex]\theta[/tex]=X motion and Y motion is mgrsin[tex]\theta[/tex]=y. Then I'm stuck how to incorporate the normal force into either of those two equations (assuming they're accurate representations of the motion of this object along this semicircle). Maybe [tex]\sum{F_{y}}=F_{n}-mgrsin\theta=mar[/tex] and [tex]\sum{F_{x}}=mgrcos\theta=mar[/tex]. I guess if I could by some mathematical bastardization equate mgrcos[tex]\theta[/tex]=mgrsin[tex]\theta[/tex] I'd get that [tex]\theta=\frac{\Pi}{4}[/tex]
I hope you all can give me a little guidance so that I can solve this problem. I know it's been posted before, but I searched, and I couldn't any help toward a solution.
What's the normal force acting on the block as it slides off the bowl?
so if the normal force equals zero then [tex]-mgrsin\theta=mgrcos\theta[/tex] and [tex]\theta=\frac{-\pi}{4}[/tex] which would have to become positive [tex]\frac{\pi}{4}[/tex] since...?
The normal force is zero as it loses contact with the surface, but why in the world are you attempting to equate "vertical" and "horizontal" components of gravity? (At least I think that's what you're doing. To properly find the components of gravity, draw yourself a diagram and apply a bit of trig. Don't convert coordinates using x = r cosθ.)
Hint: Apply Newton's 2nd law in the radial direction.
The most important equation is
[tex]N = 0[/tex]
At theta what are the forces on the block in the radial direction? Equate them as N is zero.
You will get a relation in r g and theta and velocity. Find the velocity by energy conservation
ac=gcos(theta)
