How to Calculate the Angle for a Boat Crossing a River with a Current?
  • Thread starter Thread starter bajangal1
    Boat River
To calculate the angle a boat must point upstream to cross a river with a current, one must clarify whether the angle is measured from the bank or perpendicular to it. The boat's speed in still water is 4.0 km/h, while the current's speed is 2.0 km/h. Initial attempts using inverse tangent and cosine yielded incorrect angles of 63 and 60 degrees, respectively. The correct angle is 30 degrees, which can be determined by using the sine function. Drawing the scenario accurately is crucial for solving this type of problem.
bajangal1
A boat that can travel at 4.0km/h in still water crosses a river with a current of 2.0 km/h. At what angle must the boat be pointed upstream (that is, relative to its actual path) to go straight across the river?
No equations were given but it seems like a simple trig problem, just can't get the right answer
My first attempt i used inverse tan theta (4/2) and got an angle of 63
My second attempt i used inverse cos theta (2/4) and got an angle of 60
the actual answer is 30. Either there is a very big step I'm missing or I've drawn something horribly wrong.
The first thing to determine is which angle is meant. Is the angle measured from the bank of the river to the boat's velocity vector, or is it measured from a line perpendicular to the bank? After that it's a matter of drawing the diagram and labeling the appropriate sides with the given information.
Ok i think i was drawing it wrong. i drew it differently and used sin inverse (2/4) and got the right answer. thanks!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
