Boost converter in Simulink problem
OliskaP
Hi
I am trying to simulate a boost converter in Simulink, but I have a problem. When I measure the inductor current it shows as a triangular waveform instead of an exponential waveform like I would expect, does anyone know why? Does simulink do some simplification I am not aware of?
Parameters:
Inductor with parasitic resistance: 6.5e-3H, 0.01Ohm
Diode: 0.0001 Ohm on resistance and 0.8 forward voltage
Mosfet: 0.1 Ohm on resistance
Capacitor: 1000e-6 F
Load resistance: 5 Ohm
Simulation model:
Simulink schematic of a boost converter: Vin source, inductor L, diode, MOSFET Mosfet1 driven by a Pulse Generator, output capacitor C and load resistor R, with Vout and current measurement blocks.
Inductor current:
Oscilloscope-style plot of inductor current against time on a black background, showing a triangular waveform oscillating between about 3.4 and 4.1 with peaks near 0.0955, 0.0965 and 0.0975.
That's what inductor current normally looks like in a converter. You get a triangular ripple with an average centered about output current. If you were to drastically slow the switching frequency to where the converter was no longer operating properly you would see the hyperbolic part of the curve, but the on/off time is normally short enough to stay in the mostly linear region. You'd see the same thing with a capacitor if you were to charge and discharge with a short interval.
Welcome, that ripple is a major point of design when it comes to inductor selection. Higher inductance values and higher switching frequencies result in less inductor current ripple. There are tradeoffs as always so you have to balance ripple with optimal efficiency, power requirements, and noise tolerance. Then there's the threshold for CCM/DCM. (continuous and discontinuous conduction modes). Inductance value and switching frequency affect that as well. The main thing is that output is typically noisier in DCM so in some cases you want to stay in CCM over a wider range of power outputs.
