Bungee Jump: 65 kg, 11m Rope, 36m Fall
A girl weighing 65 kg is bungee jumping from a height where she experiences an 11 m free fall followed by 25 m of simple harmonic motion. The spring constant (k) of the rope is calculated to be 25.48 N/m, and her maximum speed during free fall is 14.7 m/s, with a maximum speed of 15.65 m/s when the rope is fully stretched. The maximum speed occurs when the rope reaches its maximum stretch, which is at the end of the 36 m fall. The amplitude of the rope's motion is determined to be 25 m. The discussion emphasizes the need for accurate calculations and understanding the physics involved in bungee jumping dynamics.
getalifebaby
The girl is going on a bungee jump. She weighs 65 kg. The rope is 11m. In total, she fell 36 m. The first 11 m is free fall, and another 25m is simple harmonic motion.
1) k of rope
2)max spped
3)what point when she has max speed
4)amplitude of rope
5)how long does it take
vf^2= 2ax
delta L= mg/k
_/(k/m) A- square rt of k/m times A
initial velocity = 0
acceleration= 9.8m/s^2
1) k of rope
i got k for 25.48
2)max spped
max speed for free fall= 14.7m/s
V_max for rope= 15.65m/s
So do I add them up or just 15.65??!
36m?
4)amplitude of rope
25m?
Thanks!
why don't you show us how you solved each step, starting with the first one?
1) i used deltaL= mg/k
25m=65*9.8/k
k= 25.48
2) V_f^2=2(9.8)(11m)
V_f=14.7m/s for free fall
then
V_max= square rt of k/m *A
so sqr (25.48/65) *25= 15.65 m/s
Thanks
ok, for part 1 you have it right, but try using a more accurate value for g = 9.81 m/s2. It will actually change your final answer.
For part two, when do you expect the person to reach her final speed? And also, how did you derive "V_max= square rt of k/m *A"?
V_max when the rope reach maxium stretch.
I didnt derive it, it was a formula.
oh i see what you meant now. but using kinetic and elastic energy relationships only holds when there is only an elastic force present for a given period of time. Is this the case?
And plus, try to picture the scenario visually: once the elastic of the bungee jump is full stretched, what would you expect to happen? What would you guess her speed to be?
10K
