Engineering  Calculate Equivalent Resistance of Resistors in C++
The discussion focuses on creating a C++ program to calculate the equivalent resistance of resistors entered by the user until a zero resistance is inputted. Users are advised to store valid resistance values in an array and calculate the total resistance based on the input. There is confusion regarding the program's requirements, particularly whether resistors are in series or parallel, and how to correctly implement the input loop and array storage. Suggestions include using debugging techniques to track variable values and clarifying the use of input/output methods in C++. Overall, the conversation emphasizes the need for clear understanding and implementation of the program's logic.
Smiler7
Write a program that prompts the user to enter the resistance of each resistor continuously by using a while loop until a zero resistance is entered and store it in an array, then calculates the equivalent resistance R. Also count the number of resistors n. Test your program with R1 = 1 kΩ,R2 = 2 kΩ.,R3 = 4 kΩ and R4 = 8 kΩ . What is the equivalent resistance? Use another separate loop to print the resistances and the equivalent resistance.
I'm trying to do this question above but i don't actually get what its asking for?!
"Write a program that prompts the user to enter the resistance of each resistor continuously by using a while loop until a zero resistance is entered and store it in an array, then calculates the equivalent resistance R..."
/* Starting with this bit i could write a program where i enter the value of each resistor. But "continuously by using a while loop until a zero resistance is entered and store it in an array"?! */
It means you're supposed to enter 0 to signal that you've entered all the resistances. Something like this:
Enter your resistances one by one; enter a 0 when you're finished:
Resistance #1: 1
Resistance #2: 2
Resistance #3: 4
Resistance #4: 8
Resistance #5: 0
The result is...
Of course, you don't actually store "resistance #5" in the array or use it in the calculation.
Read the value.
If it is not zero - add it to the end of the array, continue reading.
If it is zero - don't add to the array, stop reading, proceed to the next stage.
IMHO the way it is worded now it is ambiguous, as you are not told if the resistors are connected in series, or in parallel.
Thanks guys.
but now I'm into it I am stuck...
So far i have created a program that asks straight away the value of resistance.
Say i type in 10 ohms it loops until i press 0 ohms. When i press 0 ohms it prints out the total. But the total always comes out to be zero.?!
My other problem... How do i save all my values > than zero into an array?!
I think we will try and tackle these problems first. Am i going the right way?
#include <stdio.h>
main()
double RTP,X;
/* The loop statement */
RTP=0;
do
printf ("Enter the value of Resistance in Ohms >");
scanf("%lf",&X);
RTP += (1/X);
if (X < 0)
printf ("Resistance can't be negative >\n");
else if (X == 0)
printf ("Zero Resistance entered. >\n");
printf ("\n The Total resistance is %lf Ohms.",(1/RTP));
}while (X > 0,X);
To make your programs more readable, use [noparse]
Code:
[/noparse] tags, for example
[noparse]
Code:
int main()
   return 0;
[/noparse]
displays as
Code:
int main()
   return 0;
Are you sure you should be using printf and scanf, and not cin/cout for input/output?
Code:
while (X > 0,X)
works as expected only by accident - was it really your plan to use a comma operator?
When it comes to the result - it is not that unexpected. Simplest way of checking what is happening is to either run it under debugger, or to add a line
Code:
printf("%lf, %lf\n",X,RTP);
just before if (X < 0) check. This way you will see intermediate results, they should be helpful.
Storing the information in array is a different animal, and it can be a little bit tricky if you are not told how many elements to expect. Are you expected to use STL and vector, or Microsoft's CArray, or should you use a dynamically allocated memory and implement everything by yourself? The latter seems unlikely.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
12K
