Calculate Force Exerted by Wood on Bullet
  • Thread starter Thread starter PhysicslyDSBL
    Bullet Force Wood
The problem involves calculating the force exerted by a piece of wood on a bullet that embeds itself after traveling a certain distance. The subject area includes concepts from kinematics and dynamics, specifically focusing on motion with constant acceleration.
  • Participants discuss the use of kinematic equations to find acceleration and force, with some confusion about the correct setup of the equations. Questions arise regarding the interpretation of variables such as displacement and final velocity.
Some participants have provided guidance on the appropriate equations to use, suggesting that the original poster reconsider their assumptions about constant velocity. There is acknowledgment of different methods to approach the problem, but no explicit consensus on a single method has been reached.
There is mention of potential confusion regarding the definition of variables and the need for clarity on the relationship between distance traveled and time in the context of acceleration. The original poster's use of initial velocity in calculations is questioned.
PhysicslyDSBL
A bullet of mass 0.0022 kg initially moving at 504 m/s embeds itself in a large fixed piece of wood and travels 0.72 m before coming to rest. Assume that the acceleration of the bullet is constant.
What force is exerted by the wood on the bullet?
F=N
Ok, so I need to find acceleration to plug into the equation for force, which is F=m*a. The equation I am using is x=x0 + v0*t + .5*a*t^2.
x=x0 + v0*t + .5*a*t^2 so this equation need to be set to solve for a. This is what I am plugging in:
x0 = 0
v0 = 504
t = 0.0014 (from d/s = t)
My answer is a = 0.706
The equation vf^2 = v0^2 + 2a (delta x), and set to solve for a but I am a bit confused about delta x? In this equation, vf = 0.72 and v0 = 504
I am either having trouble setting up the first equation for a, or I am using the wrong one in which case, I am not sure by what is meant by delta x in the second. Some direction is appreciated!
It was looking good, but you said this:
"x0 = 0
v0 = 504
t = 0.0014 (from d/s = t)"
This assumes constant velocity, which it's not.
You have to use this formula instead : [tex]v^2 = u^2 + 2as[/tex] where v = final velocity
u = initial velocity
a = acceleration
s = displacement.
Solve for acceleration, then multiply by mass.
x0 = 0
v0 = 504
You could use this method if you found the right time. To find the time you need to use the average speed, not the initial speed.
This equation is a better choice, but 0.72m is the distance (Δx) not the final speed. (The final speed is zero, of course.)
Thanks for the help!
I got the correct answer of 388.08 N by taking the equation v^2=u^2 + 2as and solving for a and then multiplying by mass. Both of your suggestions were very helpful in helping me to understand these concepts better!
:smile:
:smile:
It often is helpful in this kind of problem to use a graph. A graph of speed vs. time makes it very easy. The slope is the acceleration (constant -) and the distance is the area under the graph.
AM
  • · Replies 29 ·
10K
