How Many Molecules Are in a Beach Ball Using the Ideal Gas Law?
  • Thread starter Thread starter ghostbuster25
    Molecules
To calculate the number of molecules in a beach ball with a volume of 6.0*10^-2 m^3, the Ideal Gas Law is applied, which is a concept in thermodynamics. The formula used is PV = NkT, where P is pressure, V is volume, N is the number of molecules, k is the Boltzmann constant, and T is temperature in Kelvin. Rearranging the equation gives N = PV/kT. The user successfully solved the problem using this approach. This discussion highlights the application of classical physics principles in determining molecular quantities in gases.
ghostbuster25
can anyone tell me how i should approach this problem
calculate the number of molecules of air in a beach ball of volume 6.0*10^-2m^3. The air is at temperature 35degrees, a pressure of 1.1*10^5Pa and can be trested as an ideal gas.
i just want to know what area of classical physics it is
Its is Thermodynamics, and you should apply the Ideal gas law.
ehild
thankyou, i did manage to work it out as follows
PV=NkT
k beint the Boltzmann constant
T being temperature in Kelvins and
N = number of molecules and P and V pressure and volume
rearange N=PV/kT
simples :)
Good job!
