Calculate Speed of Proton in Electric Field
  • Thread starter Thread starter kpangrace
    Proton Speed
To calculate the speed of a proton in an electric field, start by determining the force using the electric field strength and the proton's charge. This force can then be used to find the proton's acceleration by applying Newton's second law (F=ma). With the acceleration known, use the kinematic equation to find the time it takes for the proton to travel 1.0 mm. Finally, add the initial speed of the proton to the product of acceleration and time to find the final speed. Providing detailed calculations can help identify any mistakes made during the process.
kpangrace
Speed of a proton?
i just don't know where to start with this? do i have to go back to basic physics??
i tried using the charge of the single proton to find the force of the electric field, and then with that force find an acceleration maybe? I am way confused
A uniform electric field has a magnitude of 2.8 103 N/C. In a vacuum, a proton begins with a speed of 2.1 104 m/s and moves in the direction of this field. Find the speed of the proton after it has moved a distance of 1.0 mm.
your help would be greatly appreciated!
What you say sounds good to me! You know the strength of the field and you know the charge of the proton. Their product is the force on the proton and, since F= ma, that force divided by the mass of the proton is the acceleration. Now use d= (1/2)at2+ vt= 1 mm to determine the time it takes the proton to move 1 mm. Once you know that, the final speed is at+ 2.1 x104.
hmmm i went through and did everything you said and i got 3.881 e10... which seemed way off and it was...
there was something i obviously did wrong, what was it?
and thank you for your help
Maybe you put a decimal point in the wrong place in line 5? Maybe you multiplied instead of divided in line 7? It's kind of difficult for people here to tell you what you did wrong if you don't show us what you actually did, numbers and all.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
