Calculate the time of a swimmer
  • Thread starter Thread starter tavo0116
    Time
To calculate the time it takes for the lifeguard to reach the child, the equation for displacement (velocity times time) should be combined with the Pythagorean theorem due to the triangular relationship of the swimmer's path. The lifeguard swims at 2.0 m/s relative to the water while the current flows at 1.0 m/s. This means the effective speed of the lifeguard must account for the downstream movement caused by the current. The problem requires careful consideration of both velocities to determine the time and distance downstream where the lifeguard intercepts the child. Understanding these relationships is essential for solving the problem accurately.
tavo0116
A child, who is 45 m from the bank of a river, is being carried helplessly downstream by the river's swift current of 1.0 m/s . As the child passes a lifeguard on the river's bank, the lifeguard starts swimming in a straight line until she reaches the child at a point downstream.
a)If the lifeguard can swim at a speed of 2.0 m/s relative to the water, how long does it take her to reach the child?
b)How far downstream does the lifeguard intercept the child?
Please help me to get started on this problem.
Which equation should I use?
Thank you
Displacement equals velocity times time. Combine that with the Pythagorean theorem. :wink:
(Hint: The displacements involved form a triangle)
(Another hint: This problem is a little bit tricky, because the given speed at which the lifeguard can swim is 2 m/s relative to the water. So before you figure out the final answer, you'll have to to take this into account.)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
