I Calculating Entropy & Enthalpy: SRK, Wilson, Antoine & Clausius-Clapeyron
The discussion focuses on calculating entropy and enthalpy for a mixture of nitrogen and carbon dioxide using various equations, including SRK, Wilson, and Antoine. The user seeks guidance on selecting appropriate A-factors and understanding the applicability of the Wilson approximation for mixtures. They aim to determine critical mixture parameters and enthalpies at specific pressures and temperatures to assess energy storage potential in the wet steam area. References to examples from Smith and Van Ness's textbook are made to clarify calculation methods, with additional inquiries about Modified Raoult’s Law and Modified Henry's Law. The conversation highlights the complexity of the calculations and the need for step-by-step guidance.
FoFi_Olli
I would like to calculate the entropy or enthalpies (steam, specific and inner energy) using the SRK [suave-redlich-kwong] equation, the Wilson approximation and (if necessary) the Antoine equation. and the Clausius-Clapeyron equation for a mixture of 0.199 mol/l nitrogen and 0.811 mol/l carbon dioxide. The critical mixture parameters (critical point) as well as the enthalpies (specific, internal and evaporation) at 50 bar pressure and 150 bar pressure and at a constant 288.15 K are to be calculated in order to then form the difference to find out how much energy , preferably in the wet steam area, can be stored.
I am a little bit stuck. Now I try to find out which A-factors to use when (SRK, Wilson, ...). Is the a-factor of wilson only useable for mixtures and only for liquids?
Science news on Phys.org
Everything you want to do is discussed in detail in Ch. 14 of Smith and Van Ness, Introduction to Chemical Engineering Thermodynamics.
I thank You a lot. :smile:
It had to come to that point, that I tried to figure out the right way with the CHat-GPT. :biggrin:
Do you mean CH. 13 of the eighth version?
I give the Examples 13.5 and 13.7 of the eighth edition a try. In table 13.7 we can see how far the enthalpy and entropy calculated with the R/K-Equation differs from the S/R/K-Equation.
It is a lot more difficult, but i have to do it with the SRK-Eq. and therefore:
Is it possible to start with the calculation of the critical point of the mixture VLE (example 13.7) to get the factors I need and then to continue like in example 13.5 to get the enthalpy of the mixture?
My aim is to calculate the latent energy stored from one pressure point of 50 bar to another pressure point of 150 bar.
And three less important last questions:
What is the Modified Raoult’s Law and what ist the Modified Henry's Law for? Are they still subkritical? Could the Modified Raoult’s Law possibly be a more easy solution or does it not fit the problems ?
Hello Mr. Chestermiller,
i would be very grateful if you could answer the questions, since i am still stuck in the calculation and especially in the order of the calculation steps :)
thanks in advance
Olli Meyer
I have the 4th edition.
I'm not sure my examples In the 4th edition correspond to yours. 13.7 involves NaOH solutions, and 13.5 involves a LiCl solution.
Sections on this in 4th edition are in Chapter 12.
Hello again,
I want to figure out which chapters you are refering to.
Can You please post a screenshot of the chapters or name the titels of the given and important chapters?!
Bellow is a screenshot of the 8th version.
have a nice day and thanks in advance
Olli Meyer
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
