Calculating Expectation Value of Angular Momentum Squared for Hydrogen Atom
6 replies · 14K views
sian130
Consider a hydrogen atom whose wave function at time t=0 is the following superposition of normalised energy eigenfunctions:
Ψ(r,t=0)=1/3 [2ϕ100(r) -2ϕ321(r) -ϕ430(r) ]
What is the expectation value of the angular momentum squared?
I know that L2 operator is:
-ℏ2 [1/sinθ d/dθ sinθ d/dθ+1/(sin2 θ) d2/dϕ2 ]
although I don't think I need to use it.
I know L2=Lx2+Ly2+Lz2
I am confused as to how to go about this. I don't think I need to be calculating an integral, as you would do to find the expectation value of, for example, x2 for a wavefunction. I think I need to calculate the number from squaring the coefficients of each part, and adding, but I'm not sure how to incorporate the L2 bit into this?
I would appreciate any help, I have been puzzling over this for ages now!
Hopefully you remember that the expectation value of [itex]L^2[/itex] in a state [itex]\vert\psi\rangle[/itex] is
[tex]\langle\psi\vert L^2\vert\psi\rangle[/tex]
When you plug in the given wavefunction, what do you get?
Now, what is the expectation value of [itex]L^2[/itex] in an eigenstate [itex]\vert\psi_{nlm}\rangle[/itex], in terms of the quantum numbers n,l,m?
Ok I know that:
〈H ̂ 〉= <S|H ̂|S>
which is:
=sum(a*nam<En|H|Em>)
=sum(a*nam<En|Em|Em>)
=sum(a*namEm<En|Em>)
=sum(a*namEmdeltamn)
=sum(|am|2 En)
=<E>
So am I right in thinking that I just have to do:
<L2> = sum(|coefficients|2 * L2)
If so, what do I use for L2?
Is it l(l+1)hbar2 ?
Thanks
Thank you for getting back to me so quickly.
I did as above, and got:
1/3(22l(l+1)hbar2 + 22l(l+1)hbar2 + l(l+1)hbar2)
Then used the values of l given in the subscript of each eigenfunction, and got an overall answer of 12hbar2. Does that sound about right?
Thanks again x
At the beginning, remember that you get a factor of 1/3 from each [itex]\psi[/itex] in
[tex]\langle\psi\vert L^2 \vert\psi\rangle[/tex]
Other than that, it seems OK.
May I ask why you do not need to use the L^2 operator explicitly? How do you end up with your
sum(an* am <En|H|Em>) term?
