Calculating Flight Time for Birds in Windy Conditions
Canadian geese migrate over long distances, flying at speeds up to 100 km/h, and must account for wind when traveling. To fly directly south in a 42.0 km/h eastward wind, the bird should head at an angle of 24.8 degrees relative to the north-south direction. The incorrect calculation for the time to cover 600 km stemmed from misapplying the Pythagorean theorem. The correct method involves identifying the right sides of the triangle formed by the bird's speed and wind speed. The community emphasizes the importance of accurate calculations and offers supportive guidance.
Ecterine
Canadian geese migrate essentially along a north-south direction for well over a thousand kilometers in some cases, traveling at speeds up to about 100 km/h . If one such bird is flying at 100 km/h relative to the air, but there is a 42.0 km/h wind blowing from west to east.
Part A) At what angle relative to the north-south direction should this bird head so that it will be traveling directly southward relative to the ground?
I got this part! 24.8 (I don't know if this is needed in the next part, so I thought I would mention it)
Part B) How long will it take the bird to cover a ground distance of 600 from north to south?
I tried to do it like the example in the book, using what is basically the pythagorean theorem. The bird travels at 100, wind is 42, leaving a hypotenuse.
So I did 100^2 + 42^2 = C^2 = 108.4km/h
Then, to get how long it takes to travel 600km I did 600/108.4 = 5.5 hours.
It was incorrect. What did I do wrong?
The answer to A) is right.
The approach in B) seems right as well, only you didn't apply the Pythagorean theorem correctly. Draw the triangle on a piece of paper... what are the straight sides and what is the hypotenuse? Then fill in the numbers and solve for the side you need.
Likes Presha
Thank you! I completely missed that.
I hope you guys can count the time you spend here as volunteer experience, everyone is so helpful!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
