Calculating Launch Speed: What You Need to Know
  • Thread starter Thread starter wilmerena
    Launch Speed
The discussion focuses on calculating the launch speed of a projectile that rises vertically to an altitude equal to one Earth radius. The formula proposed for this calculation is v_{orbit} = √(Gm/r), where G is the universal gravitational constant, m is the mass of the Earth, and r is the radius of the Earth. Participants clarify the components of the formula and its application to orbital mechanics. The conversation emphasizes understanding gravitational forces in relation to launch speed. Accurate calculations are essential for achieving desired altitudes in projectile motion.
wilmerena
Does anyone know the formula to find launch speed?
Launch in order to do accomplish what?
im sorry i think i got it.
its of a projectile that rises vertically above the Earth to an altitude equal to one Earth radius
is it:
square root of: (Universal gravitational constant of earth) x (mass of earth) all divided by Radius of earth?
<br /> v_{orbit}=\sqrt{\frac{Gm}{r}}<br />
Where G is universal gravitational constant, m is mass of orbiting body, and r is radius between bodies.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
