Calculating Projectile Speed in Terms of k, s, m, g, y, and H
  • Thread starter Thread starter ElectricMile
    Projectile Spring
To calculate the speed of a ball when it leaves the launching ramp, one must express it in terms of variables such as k, s, m, g, y, and H. The discussion emphasizes using conservation of mechanical energy, although the presence of friction complicates the calculations. Participants suggest breaking the problem into three parts to better understand the dynamics involved. The initial speed at the bottom of the ramp can be determined by considering forces, including friction and gravity, affecting the ball's motion. Ultimately, a clear approach to the problem is essential for deriving the correct expressions for both launch and impact speeds.
ElectricMile
Calculate vr, the speed of the ball when it leaves the launching ramp. Express the speed of the ball in terms of k, s, m, g, y, and/or H.
i know it will contain m, y and k
also
With what speed will the ball hit the floor? Express the speed of the ball in terms of k, s, m, g, y, and/or H.
i am so confused when it comes to creating these "expressions" i don't even know where to begin or what the heck to do.
I would use conservation of mechanical energy, of course if there wasn't friction, is the system frictionless?
it says nothing about friciton
Well imagining there's friction, you could calculate the forces to calculate the initial speed at the bottom of the ram, then friction and gravity will slow down the ball til it hits the top, then just use projectile motion.
see, that just blew over my head, I am still boggled
Divide the problem into 3 parts.
